How do I pull binary data apart?
I have two waveforms encoded in a 16-bit binary format. I can read the data in fine, but I can't quite split it into two waveforms one on each graph. Instead, I have both waveforms showing up on the same graph. Any suggestions?
(3,085 Views)
If you had posted an example I am sure we would be able to help. Lacking such I will guess.
Try running your data into a Index array node. Wire an "0" into the collumn index. This should give you the first channels data.
Do the same using an index of "1" to get the second collumns data.
If this guess is bad, please post eaxample.
Ben
(3,085 Views)
