How do I programmatically find Program Files directory?
Do I need to use the Windows Registry? If so, where is it in the registry?
I'm ultimately trying to find the Wordpad.exe file. I've been able to find where it's location is stored in the registry, but the location listed is relative to the Program Files directory. Thus, I must now find the Program Files directory, too.
Thanks in advance,
Derek
(9,100 Views)
A quick google search yielded the key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion]
with value Name: ProgramFilesDir.
___________________
Try to take over the world!
(9,078 Views)
Attached is a VI WINDOWS-FIND-ABSOLUTE-APPLICATION-PATH.VI
Given an application name in the regsitry such as WORDPAD.EXE this VI is intended to read all the necessary information from a Windows machine registry and return an absolute path.
The VI specifically checks first to ensure that it is operating on a Windows platform before proceeding to read any registry keys. I don't work with other platforms a great deal, perhasps someone would care to 'fill in the blanks'. Entrys in the registry for an application registration are either absolute or relative (I believe they should normally be relative to the %ProgramFiles% registry entry to allow system restoration to an alternative location).
I did this because I wonderd why the question had been posed. There are a number of especilly interesting things happen with respect to WORD and the way associated files are dealt with. However I imagine a scenario like this. I am running a nice fat VI with lots of demands on system resources and I want to open up a viewer application for an RTF file I have generated. I don't want WORD to open the files as its a great FAT application and has currently taken over the association for RTF files (despite it not being the registered handler in the registry - that's another story). Thus I want a lightweight application to do the work. Hence this VI.
If this does the job please let us all know.
Message Edited by Conseils on 04-16-2005 10:15 PM
(9,074 Views)
Thanks Conseils,
That was exactly what I needed!!
Derek
(9,044 Views)
I just grabbed this vi, seems to be just what I need (only need the system default program files directory part).  I noticed my application was not working right in Europe because of different naming of this directory.  I hope this programmatic approach will deliver the same directory name that the installer used for a resource file I am getting.
I'll send it off the Germany and see if it does the trick.
Thanks!
(8,897 Views)
Just wanted to say thanks for the vi.
(8,643 Views)
Thanks for the feed back and Kudos guys... Don't forget to say what you are using it for...
(8,627 Views)
