How can i implement this formula?
Hello i've to use labview to implement the formula in the image;
x with i, is a particolar element of the array nx1...
what shall i do?
(3,376 Views)
Use a for-loop to autoindex your array. This will give you each Xi in each iteration.
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(3,372 Views)
Accepted by topic author SenedLoos
I don't think you even need a FOR loop. Try this:
Message Edited by altenbach on 05-14-2009 11:25 AM
(3,346 Views)
