How do I programmatically create and save an empty project?
I can programmatically create an empty project, but when I drop an invoke node on the project, select "Save", and wire in the desired path, it results in an "Error 1".  I am getting the error on the "Save" invoke node (An input parameter is invalid.)  The only input is the path, which is correct.  What am I doing wrong?  Also, how can I specify a name for the project?
Greg
(3,583 Views)
(3,574 Views)
I think the problem is that you use the current path and strip off the path the current VI's name.  This leaves you with a path that has no filename to save it to.  Put in a build path after it where you build in a project name with a .lvproj extension.  When I did that, the error went away.
Message Edited by Ravens Fan on 08-08-2007 11:36 PM
(3,553 Views)
Well, that was easy enough.  Thanks Raven Fan!
(3,537 Views)
