I use the geotrans2.dll library. First VI to be called is Initialize_Engine() with no input parameters.
Loading the calling VI produce no Error, running the calling VI produce NO Error in the call library function.
But the return (error code) from function called produce an error. The error report indicate that a necessary text file has not been read correctly.
I then open the call library function node, select the dll manually, close the configuration dialoge and run the VI again - everything works perfectly.
This procedure has to be done each time LV is started.
My understanding:
The DLL is on the right location
The necessary text file is in the right location.
Loading the DLL by selecting it manually without running it cause no problem.
Running it at the same time is a problem.
Earlier the DLL was loaded when the VI was loaded into memory - is this still the case (LV8.2)?
Is it possible to load the DLL manually?
Or is there another problem?
