How do I open a vi with a numeric control active?
Good Day,
I have a vi that opens on a certain event in which the operator needs to enter a new value for a certain parameter.  How do I make it so that when this vi opens, the operator doesn't have to select the numerical field before entering the number (ie, I want the control to be active, and the contents selected so that the operator can type over existing value).
As always, thanks for the help.
(3,028 Views)
It seems like you want to provide the user with a default value for the specified inputs.  Initializing an input to 0 would make it active.  To do this, just input an initial value in the input, highlight it, then edit > make values default.  Hopefully I was understanding your problem correctly.
(3,020 Views)
Create a property node for your numeric control (right click it and select Create >> Property Node). Then select the property called Key Focus. Right click the property node and select Change to Write. It accepts a boolean value. Wire a true to it.
Jarrod S.
(3,015 Views)
Yup, here's a screenshot of using the KeyFocus property.
-D
Message Edited by Darren on 08-15-2006 11:46 AM
(3,019 Views)
Very good.  Thank you all for the key responses.
(3,010 Views)
