How do I move the vi FrontPanel View Programatically
How do I move the vi FrontPanel View Programatically?
I guess there are several similar sounding settings for changing the external 'size' and 'position' of the frontpanel window.  But i can't seem to find one for it's internal position - ie the position within the front panel that you change when you use the scroll bars on the side of it.  Where is this?
(3,667 Views)
VI properties, Front Panels Window, Window Bounds
(3,665 Views)
Hmmm,
Not quite sure if this is what i'm looking for.  I think - correct me if i'm wrong - that this gets\sets the external window position - rather than the internal window position - perhaps 'view' is a better word for it.  Basically i would like to be able to control what the scrollbars on the side of the vi do.
(3,663 Views)
Accepted by wideofthemark
How about VI properties, Front Panel -> Panes[] -> Origin?
(3,657 Views)
Excellent.  That's right - thanks.
(3,648 Views)
And a little VI as example...
Heavily modified/extended from original revision.
David Koch
(3,516 Views)
Forgot to add link to the original version : http://forums.ni.com/t5/LabVIEW/A-picture-as-a-dialog-box/td-p/236851
David Koch
(3,503 Views)
