How do I make displacement measurements using a linear encoder and NI-9401?
How do I make displacement measurements using a linear encoder and NI-9401?  I couldn't find any examples for a linear encoder.
Thanks in advance.
(2,992 Views)
Hi VI Joe,
I would recommend opening a LabVIEW shipping example that is extremely close to your desired application and then changing it.
For example, you can use the shipping example titled "Measure Angular Position.vi".
(Example Finder » Hardware Input and Output » DAQmx » Counter Measurements » Position » Measure Angular Position.vi)
You can then change the measurement from Angular Encoder to Linear Encoder.  (See the attached image.)
I hope this helps,
Kevin S.
(2,971 Views)
