element of cluster of cluster acces
i'm trying to make a element of sub cluster visible or unvisible according to another
i succeed to acces first level but not more, and i don't think i used a good way to do
how can i make ringmenu option visible if methode 1and  not visible if methode 2 ?
here an attachement of what i 've tried...
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,965 Views)
Accepted by topic author tinnitus
Hi Tinnitus,
i can't open your vi at the moment, but maybe  i can help without it. You can use a reference to it to make it visible or invisible. If you want to hide to element, then you need both references. You can get the refernce with right click in development mode, or with searching it while running.
Hope it helps.
Mike
(2,961 Views)
Hello Mike,
i used a reference but surely not  in  efficient way...
sorry i always forgot , the same in 8.5
Tinnitus
(2,946 Views)
As Mike indicated, simply create a direct reference to the sub-cluster that you're hiding/unhiding by right-clicking on that cluster and selecting Create -> Reference. Then you don't need to index out the reference from the Controls[] property for the parent cluster.
(2,932 Views)
