How do I load a control's values from those stored in it's typedef?
How do I load a control's values from those stored in it's typedef? I have a control that is linked strict to a typedef. I open the typedef and change the values and specify save as default, and then I would like to have the control (an instance of the typedef) to have it's values revert to those of the typedef default values. Is there a way to do this?
(3,633 Views)
What kind of control are you talking about?
Mike..
Certified LabVIEW Architect
LabVIEW Champion
(3,625 Views)
I probably should have mentioned that the control is really a cluster of controls, including many different control types. The control in question is a string control (string constant->change to control).
(3,621 Views)
The problem is that the default value for a control is not saved as part of the typedef - or at least a part of the typedef that is enforced. As a result, if you change the default for a typedef, new instances of the typedef will show it but existing instances will not be changed.
Mike...
LabVIEW Champion
(3,619 Views)
So I have an enhancement request: I suggest adding to every control's "right-click" menu:
DataOperations->Reinitialize to typedef default
and have it greyed out for controls which have no associated typedef.
(3,615 Views)
Hi DEppAtNGC,
Thanks for the idea. I have filed a product suggestion with R and D with your recommendation.
Jeff | LabVIEW Software Engineer
(3,588 Views)
