How do I keep the cursor name attached closely to the cursor.
I have an application where I have cursors with x,y values being displayed in the cursor name location. When I move the cursor to other locations the cursor name gets lost from view. I have attempted to write code to center the cursor by finding the center of the x and y scales and when called the cursor will move to the center of the screen. The problem is that the cursor name does not also come to the center of the screen. It is lost somewhere out of view. I would like to use the labview bring to center command if there is one so the name will stay the set distance from the cursor as it was wen the cursor was first created.
(2,764 Views)
Hi Ernie,
I'm not sure why your cursor name gets lost when you bring the cursor to center. I've just tested with LabVIEW 8.5 and the cursor gets centered along with the cursor name. What version of LabVIEW are you using?
Stanley Hu
Applications Engineering
http://www.ni.com/support
(2,736 Views)
