How do I hilight a section of a string array?
I have a VI that displays a string array.  The display is roughly 20 strings high by 20 strings wide, while the arrays in it are much larger.  I am comparing two files to find differences.  When differences are found, I want to somehow hilight or emphasize the block or string that is different.  Is there a way to do this?  Is there a way I can visually hilight one section of my string array?  I looked through the different property nodes, but couldn't find anything to do this.
Thanks for the help,
Jeremy Backer
Jeremy Backer
CLAD
(2,815 Views)
Accepted by JMBacker
Hi JMBacker,
I am not sure if Arrays can highlight only a particular section.
But you could do one thing.
Display the Array in a Table and then chage the background color of those particular cells where the differences are found.
Ritesh
(2,812 Views)
That's gonna work.  Thank You!
Jeremy Backer
CLAD
(2,807 Views)
