How do I handle files that were opened using my LabVIEW application?
I have LV 2009.  Not sure if it is in previous versions.
Message 11 of 18
(1,520 Views)
Ravens Fan wrote:
Nickerbocker wrote:
@Ravens -
If you put:
SuperSecretPrivateSpecialStuff=True
In your LabVIEW.ini file, it will unlock an "OS Open Document" event to use in an Event Structure block with a "File Path" node on the left-hand side.  Whenever the application is launched via a file in the OS, this event is fired (even if your application is already up-and-running).
Works like a champ and is fairly straightfoward! 🙂
That's good.  But your post #2 where you mentioned it gave absolutely no details.  But if you feel you gave enough information there that could help someone else in the future that you could mark your own message as the solution ......
Well, it was the solution I had for the problem I posted, and I wanted to make it clear that the issue was resolved.  When I had originally posted it, I was expecting that this was a known solution and I was just behind everyone else in the learning curve.
Message 12 of 18
(1,519 Views)
The solution marker is designed not only to tell that a question is answered, but also allow someone else browsing through the thread to jump directly to the answer.  I've heard of that the supersecretstuff, but didn't know how it would apply in this case.  And the vast majority of the people reading these threads have probably not hear do that option at all.  So the simple message you posted in reply #2 really isn't a solution because it can't help anyone.  Now if you had posted some details has to how it was a solution, or a link to the thread where you discovered how it works, then you can consider that a solution.
Message 13 of 18
(1,497 Views)
Here isa snippet (for LV 2009) with the actual code:
Ton
My LabVIEW Ideas
Message 14 of 18
(1,482 Views)
I notified a Moderator to change it.  Thanks.
Message 15 of 18
(1,462 Views)
Ton
Thanks for the snippet!
It is probably Noteworthy that the SuperSecretPrivateSpecialStuff=True in the LabVIEW.ini file is not required to load a VI with an Event Structure that has the "OS Open Document" event handled.  Only required to be able to select it in a new VI.  Once setup in an existing VI, a user can interact with the event structure with or without the LabVIEW.ini toggle.
Message 16 of 18
(1,458 Views)
No need to notify the moderator.  If you go to the Options menu to the upper left of that particular message, you can unmark it as the solution.
Message 17 of 18
(1,435 Views)
I did not know that.  Thanks.
Message 18 of 18
(1,427 Views)
