String storage
I am trying to determine where a string (constant?) is used. I used slickEdit to search the whole directory but it found nothing. Are strings stored as something other than standard ASCII codes?
thanks,
jvh
(3,257 Views)
Accepted by topic author jvh75021
If you want to find a particular string in a VI or hierarchy, you should use Edit>Find and Replace.
(3,249 Views)
An addition to Dennis' answer:
LV is using zip compression for it's saving routines... But you can still try to find some strings in the files Smiley Wink
(3,229 Views)
And some more background:
LabVIEW 8 started storing the block diagram compressed
LabVIEW 8.5 (or 8.6) started storing the Front Panel compressed
I think that only the VI description is still saved 'as is'
Ton
My LabVIEW Ideas
(3,210 Views)
