Showing results forĀ
Search instead forĀ
Did you mean:Ā
How do I grab data from a url?query using LabView 8.0?
If I copy the following url in my web browser, it will give me the quote of BBD-A.TO symbol from yahoo. The data is comma separated (csv).
I would like to know how to grab that information using LabView. I tried using datasocket VIs but I was unsuccessful, it seems that as soon as I put the query part of the url, I am not able to read (timeout occur).
I think there might be another way to do it using .NET "httprequest" and "httpresponse" classes but again I was not successful.
I am really new to this, thanks for your help.
(3,254 Views)
Hi Ben,
      Try adding "[text]" to the end of the URL that you're supplying to the "Datasocket Open (Read)".  In your case: http://finance.yahoo.com/d/quotes.csv?s=BBD-A.TO&d=t&f=sl1d1t1c1ohgvj1pp2wern[text]
Also, Jeremy L posted a GetHTMLSourceString.vi.
Cheers.
Message Edited by tbd on 01-07-2007 12:08 AM
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,241 Views)
You were right, [text] solved the problem.
Thanks a lot for your help !
(3,223 Views)
Thank YOU - I appreciate the stars!
(3,205 Views)
