‎01-30-2008 03:28 PM
‎01-31-2008 02:19 PM
Hi Root Canal,
Is this a LabVIEW issue. Which version of LabVIEW are you using? I am not completely sure if this is the right forum to post this issue. I would try this forum for more information (if this is not a code you are writing in LabVIEW). Hope this helps.
‎01-31-2008 02:50 PM
‎02-03-2008 10:43 PM
Hi Root,
There are softwares available which convert 3DS formats to ASE. However, there is no specific object in LabVIEW to do the conversion or import a 3DS file. If 3DS Max has ActiveX interface, you can use those objects in the LabVIEW ActiveX containers. Another method is to use OpenGL. Look at the following post on the topic OpenGL and Labview. Hope this helps.
‎02-04-2008 10:15 AM
Thanks Nitin T,
I've attempted to translate 3DS to ASE using two separate software packages without success; that is to say, I was unable to read the generated ASE files into labview. What conversion software is recommended?
Thanks again,
Root
‎02-06-2008 06:55 AM
