How do I get LV to go to Edit mode when I stop a VI? It use to.
Recently, my LV stopped going directly to Edit mode when I stopped a vi. I can find any setting to set this.
(2,671 Views)
  1. Make sure that you have not selected Change to Run Mode from the Operate menu. (Shortcut Ctrl-M)
  2. Make sure that the file is not Read-Only.
(2,671 Views)
I found the answer in the Options, Miscellaneous. The "Open VIs in Run Mode" must be UNCHECKED. Somehow it had gotten checked.
(2,671 Views)
