How do I embed a running LabVIEW child window within C?
I need to write my application using Borland C++ but I want to use LabVIEW toolkits for analysis. I have been doing some initial investigations into how I can link the LabVIEW into my C++ code. I have been successful in being able to create a LabVIEW dll and then call that from my C++ code and set the LabVIEW window as a child of my C++ window by calling the 'FindWindowA' function of the Windows API from within LabVIEW to supply my C++ code with a handle to the window.
I thought I'd done the tricky part until I then tried to make my LabVIEW test VI a little more realistic - so instead of just suppling the handle to itself, I wanted it to sit in a loop taking commands until I was finished with it. This is where I am running in to problems. If I have just the one VI with the 'doing something' loop in it as well as passing the handle, my C++ code waits until the VI is closed before passing the handle. I've tried splitting my LabVIEW code into the 'do something' VI, with the window I want to embed in C++, and a second VI which loads the 'do something' VI and which also returns the handle. When I run this in LabVIEW it acts I as I'd intended but when calling from C++ no window appears.
So, to try and clarify, from C++ I want to get a handle to a LabVIEW VI with a front panel that I will eventually display graphs and which the user will need to make selections and press buttons on. I want to use that handle to set the LabVIEW window as a child of my C++ window, and then I want that VI to keep running until the user selects to close it.
I've attached the LabVIEW code - I don't think the C++ code will be of much use here but I can give details if necessary.
Thanks in advance for any help.
CAS
(3,192 Views)
Can you try zipping that code up again as when I try to open either of the VIs they close LabVIEW immediately. Do you experience the same behaviour on your development machine?
Tom
NIUK
(3,164 Views)
Dear Tom
Thanks for the reply - apologies for my delay but I have been out of the office. I have just downloaded that zipped code from the website and it's okay on my PC. Could it be a version clash? Currently I am running the LabVIEW 8.2 Evaluation package and the VIs were created using that.
Anyway, I'll re-attach a fresh zip file to see if that's any better.
Cheryl
(3,140 Views)
To anyone with a similar problem:
After not resolving my problem in this thread, a posted a new question which contains the solution. The title of the thread is:
'Get a handle from a LabVIEW dll for C++ before the vi closes'
Cheryl
(3,082 Views)
