Stand-alone aplication and WEB publishing
Hi there!
I'm trying to set up a remote experiment on a computer that does not have LabVIEW installed. To do this, I need to run a stand-alone aplication with the desired VI's and publish it. Is it possible? And if so, is there any license that needs to be purchased (or something else that needs to be payed) to do so?
We do have all the LabVIEW licenses on the computers in wich we develop the experiments.
Thanks in advance,
Leandro Ribeiro
(2,966 Views)
In order to create a remote panel on an executable, follow these instructions :
1) Create your project including your file
2) Create your html file in LV : select Tools»Web Publishing Tool
3) include it in your project
4) Create your executable including the VI in source files and your web page in dynamic files
5) Create your installer and go to Additional Installers  and select NI LabVIEW Run-Time Engine and NI LabVIEW Deployable License
6) Install it on your target computer
7) Check the ini file to enable the web server and the web server path.
 webserver.enable=true
WebServer.RootPath
😎 Launch your web page : http: //IP adress of your computer/web page name.html
Regards.
(2,932 Views)
That worked! 🙂
Thanks so much!
Leandro
(2,929 Views)
