How do I display webcam feed on a front panel
Hi All...
I'm trying to code up a LabVIEW application which will take a webcam feed from a webpage (such as www.camcentral.com) and display the webcam feed from a specific location (e.g. Sydney) onto the front panel of the VI... has anybody done anything like this before? Know how I'd go about getting started with it?
Cheers,
M.J.
(2,660 Views)
You could use an ActiveX container...
The ActiveX object you would use is the Microsoft Web Browser and you can use property nodes and invoke nodes to control it. The attached code shows the basic implementation.
Sarah
Applications Engineer | National Instruments | UK & Ireland
(2,641 Views)
