How do I determine what element in an array was right clicked on?
I have an array set up on my front panel. When the user right clicks on an element in that array, I would like them to be able select from 3 different options. I have the shortcut menu working, but I need to know which element in the array the user right clicked on to determine what values to change. How can I get the index of the element?
Thanks for any help!
Message 1 of 9
(5,380 Views)
Accepted by redsnapper
Message 2 of 9
(5,369 Views)
Solved it! Thanks
Message 3 of 9
(5,351 Views)
I was curious and thought the proposed solution was heavy depending on what you need to do exacly...
So here's some alternate solution, hope it may be helpful. You can also write some value to the clicked element.
Message 4 of 9
(5,333 Views)
Deleted dup.
Message 5 of 9
(5,333 Views)
Here is my solution, from my toolbox:
It accounts for the possibility of the array being scrolled away from 0,0.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 6 of 9
(5,318 Views)
Couldn't you get index values from the array property node?
Also this doesn't account for if scrollbars are seen or not.  And I usually like to know if my range is valid, because again I could be clicking on a scrollbar, or label and still get the Mouse Down event.
Here is one I posted a while ago.
http://forums.ni.com/t5/LabVIEW/Interesting-way-to-detect-array-index-from-mouse-position/m-p/286841...
Message 7 of 9
(5,272 Views)
I think you are looking in all the wrong places. To get the index of a clicked array element, you can calculate that from the coordinates given the elements size, indexval, and orientation.
Here is an old example.
Message 8 of 9
(180 Views)
This might be helpful.
Message 9 of 9
(146 Views)
