How do I count the number of *'s in a string?
I need to count the number of * in a string of carakters. And the return the number. 0 for no *'s in the string 2 for two *'s in the string and so on.
It's probably quite simple but I can't figure out how!
Message 1 of 10
(4,870 Views)
The attached vi will show you one way of achieving this, it's not the unique, perhaps not the best, but can give you some ideas...
Hope this helps
Message 2 of 10
(4,870 Views)
Works like a charm!
Message 4 of 10
(4,870 Views)
Like this.
james_t_dk wrote in message
news:506500000008000000682E0000-1002247793000@exchange.ni.com...
> string and so on.
[Attachment Untitled 10.vi, see below]
Message 3 of 10
(4,870 Views)
Just use 'Match Pattern' in a while-loop. Wire the string to the input of
the while loop and use the shift register inside the while loop to wire to
the string input of match pattern. Match string should be: \* hence '*' is a
special character...
Complete the while loop by wiring a >=0 to 'offset past match' and the while
condition.
Supply an email adres if you want to receive an example...
Gr,
Frank Lubbers
Message 5 of 10
(4,870 Views)
If you could send an example to bwillis@ucla.edu, i'd much appreciate it.
BW
"Frank Lubbers" wrote in message news:<3bd00eeb$0$19399$e4fe514c@newszilla.xs4all.nl>...
> Hello,
> condition.
> Gr,
> Frank Lubbers
Message 7 of 10
(4,870 Views)
Or, to complement CraigGraham's answer, I offer the attached VI which includes two alternatives.
Richard
Message 6 of 10
(4,870 Views)
James,
Here is another alternative solution. This solution is different in the way that it does not make use of shift registers or loops. I only used built in functions to get the count. I hope this helps. /Mikael
Message 8 of 10
(4,869 Views)
Nice. Probably quite a bit more efficient than previous suggestions, mine
included.
Mikael Garcia wrote in message
news:506500000005000000C1480000-1003545641000@exchange.ni.com...
> James,
Message 10 of 10
(4,869 Views)
There have been several solutions to the question and I find Mikael's particularly good (see http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000682E0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0 ). Out of curiosity, I've examined the options a little further and found Mikael's answer to be the fastest (in microseconds: 1.56 (Mikael); 2.10 (Richard); 3.08 (Gorka Larrea); 4.42 (Richard); 5.02 (CraigGraham)). May be several of us could benefit from learning of the time penalty in using loops where built-in Vis would do? Richard
Message 9 of 10
(4,869 Views)
