How do I copy data from a Labview table or plot and paste it into a text or Excel file?
Take a look at this example program.  It shows how to create a report in Microsoft Word.
-Justin D
Message 11 of 15
(2,262 Views)
Thanks Justin. I had already gone through those vi s. But those does not show how to link an array to be pasted in a Word document. I am getting the output as a table of array . I could not convert this array data to string that a word document accepts.
Thankyou
Nghtcwrlr
Message 12 of 15
(2,253 Views)
Hi blk,
I couldn't find an easy way to do this.  The only easy way that I know how to do this is to use the Report Generation toolkit for LabVIEW.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/5769
I am not an expert in how to use Microsoft's ActiveX API so I'm sure it is possible to do what you want with just ActiveX but I'm not sure how to do it.  I would reccommend that if you do not need to paste your data in a Word document, use an open format like txt to do so.  It will make your life much easier.  If you absolutely need to use Microsoft Word, getting the Report Generation Toolkit will make this much easier.
Justin D
Message 13 of 15
(2,237 Views)
Thankyou very much Justin . I changed from Word to wriote in to a text file. Thanks for the info.
Regards
Blk
Nghtcwrlr
Message 14 of 15
(2,225 Views)
    Can you help me to convert the llb's version to 2011,I can not open it.
    i am using labview2011
    thanks a lot
Message 15 of 15
(1,341 Views)
