How do I configure USB 8451 using SPI and 4 Chips for parallel acquisition?
<I have re-posted this query due to a lack of response on the DIO channel>
I am about to use Melexis 90316 IC's: 4 of them. I am communicating using the SPI framework with the USB 8451. Figure 17.4.2 of the datasheet I have attached essentially shows how I would connect the chips. Here's the problem: I am looking to acquire all the data at the same time, but the 8451 only has one MOSI and one MISO port. Is there a way to setup the DIO channels on the other side of the device to acquire the MISO data continuously and in parallel from all 4 chips? Additionally: I have just begun to familiarize myself with the C++ API: do I have to run everything as a script to make things go faster? How does one do continuous streaming of input data without constantly having to query each IC?
Thanks for your help!
Nathan
(3,432 Views)
Hey Nathan,
Unfortunately the 8451 can only communicate with one device on the MOSI/MISO at a time.  Therefore for this application you will need 4 8451's to acquire MISO data continuously and in parallel from all 4 chips.
Jason W
Applications Engineering
(3,414 Views)
Do you know how to have the MOSI line stay low until a data bit drives it high?  Right now, mine stays high and then goes low.
(2,604 Views)
