How do I compile Labview program so multiple instances run on one computer?
I would like to have the ability to run multiple instances of a single executable Labview program  on the same computer.  Is there an option I should set during compilation?
(4,898 Views)
Completely ignoring issue surounding shared resources (same file. I/O devices, network connections etc.)
Just copy your exe to unique names and run them.
EG
App name = Test.exe
copy to new names
Test1.exe
Test2.exe
Ben
(4,895 Views)
There is an INI setting:
allowmultipleinstances = TRUE
Ton
My LabVIEW Ideas
(4,877 Views)
Ton
The INI file setting is for running multiple instances of LabVIEW, not necessarily multiple instances of a LabVIEW run-time application, correct?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(4,873 Views)
The linked wiki page suggests it also works for executables.
Ton
My LabVIEW Ideas
(4,856 Views)
Do you need the multiple instances to communicate?  If so, use the INI file settings and VI server to launch them into the same run time engine.  These settings in your INI file may be of use.
server.tcp.enabled=true
hideRootWindow=true
server.tcp.port=nnnn
server.tcp.access="+localhost"
Make sure you use a unique port number.  Launch your main VIs by first using Open Application Reference with the port in your INI file and "localhost" as the machine name.  Then use this application reference to open your main VI using Open VI Reference.  Run it using the Run method with Wait Until Done set to FALSE and Autodispose Ref set to TRUE.  Make sure it has its front panel open before you close your launcher or the LabVIEW runtime engine will close (since you have the VI ref, you can do a slow poll on the execution state or front panel open/closed properties).
Be careful with shared VIs.  Reentrancy and VI templates are your friends.
(4,837 Views)
