How do I change the name of several plots of a graph/chart. (programmaticly)
Heey everyone, title says it all.
I already tried using active plot with a forloop, but for some reason that doesnt work for me :s
Checkout the picture in the appendix, that`ll explains my problem.
In the block diagram you`ll see a stringarray :
0 = name 1,
1 = name 2 and
2 = name 3.
For some wack reason the plotnames are set in a different order. Also checkout the program while using debugSmiley Tongue, then you`ll understand directly what my problem is.
Thank you!
Currently using labview 8.2.1
(3,203 Views)
Accepted by Grasman
Just a quick suggestion:
Switch the order. Put the 'active plot' on top, then change the plot name.
That should do the trick.
Cory K
(3,199 Views)
You also do not need the 'array size' wired to the number of iterations in the For loop,
LabVIEW will autoiterate since you passed an array into the loop.
Cory K
(3,196 Views)
omg how could i be so stupid Smiley Indifferent
Thanks alot Cory, works great now !
(3,191 Views)
Haha, it has nothing to do with stupidity.
Sometimes you just overthink a problem so much that you miss the simple stuff Smiley Very Happy
Cory K
(3,184 Views)
