How do I change a 1D array to an element?
You can do it in many ways. Check the attached example.
Message 11 of 20
(1,660 Views)
Thanks!!!
Now Iam looking for a solution to one question.Searched throughout forum and tried my own way,that is:-
Is it possible to edit an array at run time??Here example showing array values changing from 10,20,30...while running,That time I want to enter my own input value in any of the array index.Is it possible?
Sorry I don't started a new thread because the example attachment is in this thread.
Message 12 of 20
(1,632 Views)
Look into the Replace Array Subset VI in the array pallet.
Message 13 of 20
(1,629 Views)
Yes,using "replace array subset" we can replace array element in a particular index at the time of coding.But I want to change my array element in the frontpanel itself while the VI is running.Is it possible?
Message 14 of 20
(1,614 Views)
That makes no sense. The only way to actually replace an array element is to run a VI, so of course the answer is yes.
Message 15 of 20
(1,606 Views)
Hi jkuttu,
If you want to manually change the value of what is being used to replace an element at a particular index in your array while your VI is running then you should use a control instead of a constant as the "new element" input for the "Replace Array Subset" function. This will allow you to enter any value you want on the front panel while the VI is running and this value will be input to the specified index of the array.
I hope this helps.
James D.
Message 16 of 20
(1,591 Views)
Thanks James.It worked.But that particular array index seems to be not moving.So Iam trying in a way to create a mouse click event in the array.
Thanx and suggestions are welcomeSmiley Happy
Message 17 of 20
(1,570 Views)
Hi jkuttu,
I'm not sure I know what you mean exactly by the array index not "moving". What about the array do you want the mouse click event to control? If you can share some more detail on the purpose of the event then I can provide some guidance and suggestions on how to accomplish this in LabVIEW.
James D.
Message 18 of 20
(1,552 Views)
Hi James,
               Our array values are changing continuously.When we provide a control on any of the index that index seems to be not changing itself,that what I mean.Anyway I will post some code here.
Message 19 of 20
(1,536 Views)
Whatever you are saying still makes absolutely no sense. Yes, please post some code!
Message 20 of 20
(1,526 Views)
