Tektronix TDS2014 - virtual oscilloscope
Hello
I would like to know if anyone may have had to deal with the implementation of a virtual device based on oscilloscope Tektronix TDS2014B or similar. My job is to move the functionality of the oscilloscope to the computer screen and perform all functions from a commuter. The oscilloscope is connected to the computer via a USB cable. Maybe someone can help me in this topic because as long as I'm standing in place. Already installed the drivers tktds1k2k individual functions work but can not cope with a combination of the whole. I found the video on Youtube that shows what I want to achieve http://www.youtube.com/watch?v=kDmuYDK3_dg. Could you please help on this subject.
(3,572 Views)
Help with what what specifically? I get an error when I click on your link.
(3,562 Views)
Maybe this link will be work You http://youtu.be/kDmuYDK3_dg
I need help with look up in example VI how I should make my work.
(3,557 Views)
Since you say you have gotten the driver to work, then what you are faced with is designing a front panel. Take the LabVIEW tutorials (or a class) and pay special attention to the event structure. For example, with a front panel knob value change event, you would call the driver function the changes the scope's vertical range. Another knob and another event for the horizontal, etc. There is a simulated scope that ships as an example that you can use for other ideas.
(3,552 Views)
