How do I build array 2-D using while loop whith shift register?
I would like the data acquisition'results be showed, in a array 2-D,each interation and weren't showed data acquisition'ending as my example.
Coud somebody please help me?
(4,467 Views)
I am not to sure what you are looking for. is the attached any help
(4,467 Views)
Actually the vi was slightly differet than i intended. The constant should not have been set to zero. attached is the correct file,
Gillie
(4,467 Views)
If you want the front panel to update during the loop runs, your indicator must be inside the loop.
The attached example should give you enough ideas to take it from here.
Best is to initialize the final array size from the beginning. If you populate it with NaN, they won't show on the graph.
Similarly, you can place the indicator in the outer loop to just get an update for an entire row or column at a time.
(4,467 Views)
Sorry, I just noticed you're using LV6.0
time to upgrade!
(4,467 Views)
Thought I didn't expressed very well you answered my question!
Jota.
(4,467 Views)
