How do I alternate an output value between 2 settings at a prescribed rate?
I would like to simplify a sine wave into simply a saw tooth with a single point at the top and bottom of the wave. My external system cannot keep up with the rate I need for the sine wave so it is useless feeding it all that extra data. I basically want to set the value at say 50 wait a second then change it to 0 then wait a second then change it to 50... etc.
I don't know how to wire more than one thing to a channel. I assume I need a loop of some sort.
Thanx for the help.
(2,480 Views)
DO "Serach Examples" for Continuous Analog Output.
One of those examples "Function Generator"? Gives you a triangle wave output.
Crank down on the update rate, Bingo you are done.
If you care to look, you will find a loop on the diagram when you are done.
Ben
(2,480 Views)
