I am trying to get labview to realize that a bottle is placed in front of it, therefore this will enable the tag which in turn will allow the bottle to move to the next location. However when I run the program the picture that I se of the bottle is awful. I went to MAX or Measurement & Automation Explorer and I have the image or video set to 640x480 YUV(4:1:1) 30fps. In MAX and Vision Assistant 7.1 the image is as expected. How can I get the image in LabView to be the same as the other two program. The capture I currently get won't allow me to view the image properly making it impossible to accomplish my task.
You might have missed the following thing. The default parameters of the video acquisition are different at MAX / Vision Assistant and at Labview. So you have to set them up explicitly before starting the acquisition.
Alexander
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
