How do I add meta tag data to a TIF image file
this example with .Net ist very good
I try to save a 16bit Image Stack in Tiff File,
Could you help me?
Diego
Message 11 of 15
(1,640 Views)
Started using the Write TIFF Metadata code today to write some custom tags and it works great.  Now I need to read the tags.  Tried doing this using the BitmapMetadata GetQuery method, but no luck.  Anybody have any examples of doing this with .NET?
Message 12 of 15
(1,441 Views)
When I load your program, I get an error: "Invoke node contains unwired or bad terminal". It is referring to the third BitmapFrame in "TIFF Bitmap Encoder Create" task of the state machine.
Florian
Message 13 of 15
(1,287 Views)
I noticed also the error, possibly the API changed. Corrected the invoice node in case somebody is looking for it.
Message 14 of 15
(759 Views)
Sorry but this thread is still useful in 2024!
Who is able to read tag from a TIFF file  (here the wonderful code "Write TIFF Metadata 2" only wrtie metadata)?
Who is able to give a name to a used-defined tag?
Thanks a lot.
Message 15 of 15
(313 Views)
