How do I adapt the following structure using Call Library function node?
I am using Call Library function and Adapt to type with LV8.2. How would the cluster items be assigned for the follwoing structure?
typedef struct job {
    char name[AT_BUFFER];    // name of attribute
    union {
        char *value;    // if num_value = 1, attribute value held here
        char **values;    // if num_values > 1, attribute values held here
    } val;
    unsigned int num_values;    // the number of values pointed to by attr_value
    struct job *next;    // next attribute in list
} job_t;
where value for AT_BUFFER is defines as
# define AT_BUFFER    1024
Rachana
(2,664 Views)
Please read the linked KnowledgeBase article on using Adapt to Type for the Call Library Function Node.  Thanks!
(2,629 Views)
