Built-in 2D peak finder?
I was wondering if LabVIEW has a built-in 2D peak finder. I found something called "Waveform Peak Detection.vi" that finds peaks of a 1D waveform, but no equivalent VI that finds peaks in a 2D array of data.
Allen
(3,496 Views)
Hi Allen,
Here is a VI that detects 2D peaks of data. I hope this helps!
Amanda Howard
Americas Services and Support Recruiting Manager
(3,468 Views)
Hi Amanda,
Thanks alot! I was wondering if you can resave this in an older version of labview, like version 7.1?
Thanks!
Allen
(3,463 Views)
Hi Amanda,
I looked at this VI, and I think it finds the peaks of each 1D waveform separately instead of finding say the peaks in a topographical map represented by a 2D matrix. Is that right?
-Allen
(3,443 Views)
Yes, Allen. That is correct. Is that going to work for your application?
Amanda Howard
(3,419 Views)
