Showing results forĀ
Search instead forĀ
Did you mean:Ā
How can i set case structure always true on boolean impulse?
Hello everyone! I need a little help. All i want is to set a condition when to acquire data from my acquisition board. I have a sinusoidal pulse and when value its near zero (between 0.5 and -0.5) i want to start to write data and also stop condition. How can i make my case structure to remain set to true until next condition? Thanks in advance!
(4,227 Views)
Hi sda,
don't use the inner while loop. Especially when it tends to run endlessly…
When you want to keep values from previous iterations you need to learn to use shift registers. And you need to learn to combine boolean signals like
IF current condition <> previous condition THEN
  switch condition
ENDIF
(4,214 Views)
1.  You do NOT want that while loop that does the range check.
2.  You should use a shift register to keep track of if you are running or not.  So when you are in the range, invert the boolean you are storing in the shift register and use another case structure to handle the reading or stopping.
(4,212 Views)
Thank you! I'm a beginner in labview and any advice is welcome! šŸ™‚
(4,205 Views)
I highly recommend tutorials if you are really new.  Otherwise, just keep asking questions.  You'll figure it out soon enough.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
(4,181 Views)
