How can i plot data from 2d array one at the time on the same waveform graph
hello. everyone. i have two sensor readings build into a 2d array. i would like  to plot them as bar  on the same waveform each a the time so each sensor reading is display as one bar on the graph.the problem is that i dont really know how to access each data at the time and sent each sensor reading on the waveform.the  2d array is actually a two rwo/100 columms with the 100 representing the reading from each sensor each 1s.
Message 1 of 23
(6,480 Views)
You should use a chart instead.
Message 2 of 23
(6,462 Views)
Is this something you are looking for?
CLD
Message 3 of 23
(6,437 Views)
You probalby did not notice that the first VI was LabVIEW version 2012, thus he won't be able to look at your VI, which is in LabVIEW 2013.
Message 4 of 23
(6,433 Views)
Thanks altenbach, I will resave it to 2012 & upload it.
CLD
Message 5 of 23
(6,425 Views)
Thanks Sir for the answer.but i tried some stuff and i was able to plot both signal into the waveform.but the problem is that when i configure the graph to show each signal as a bar  its output both signal one on the other.i could see this  when i greyed out one of the plot.i would like the graph to show the value of plot0 which represent one of the 2d array rows as bar 0 given that is shows only one value at the time which i already know how to do and the valu of plot 1 which are the second row of the 2d array as bar 1(i need this because i want to customise one bar plot without changing anything on the other).is there a way to access each rows of the 2d compare the valu to some limit and send them both to the graph?
Message 6 of 23
(6,405 Views)
Please be more specific than "tried some stuff". Your description is not clear at all. Please attach your newest version. Also explain what you mean by "bar". Maybe add a figure showing how things should look like.
Message 7 of 23
(6,400 Views)
Message 8 of 23
(6,396 Views)
sorry sir for the lack of details. i had more info on my block diagram concerning what i am trying to achieve. basically i simulated two signal, converted the waveform data to arrdy data type feed it to the loop number of iteration.in for for loop i read from the array a number at the time do some comparaison to some limit and send this number to build array so i can send it to the waveform.which menas that at each iteration of the for loop a single valu of both signals is sent to waveform(with the waveform configure to show it as a vertical bar line).the color of the bar line is selected dependently of the value of data.so on my graph, i should see each(200ms) two separated bar line with the appropriate color instead one two bar line one on the other as it is know.
i hope this is clear enough.
thanks.
yannstephen
Message 9 of 23
(6,387 Views)
As I said, use a chart instead of a graph. See my VI attached earlier.
(If you want to use a graph, you need to build the array in a shift register or feedback node.)
Message 10 of 23
(6,380 Views)
