How can i get the radial frequency and the fourie index after FFT?
Hi:
   I have a 2D array of real,after FFT I get  a 2D array of complex.
   the question is how can i get the  radial frequency and the fourie index from the complex number?  Mybe the question is so easy,  but i am so confused.  please help me!
(3,328 Views)
Hi:
2D array is (s,φ),  where s is a distance and φ a angle.
The sentence is like this
"through the continuous Fourier transform with respect to radial distance s and the Fourier
series with respect to azimuthal angle φ where w is the radial frequency and k is the Fourier
index."
In fact it is a 2D FFT translate.
(3,315 Views)
This is not very clear. Are you talking about the input array or the result array after FFT?
Can you attach a small example that containst your 2D array as a diagram constant?
If you are talking about the input array, Is it a 2D array of complex numbers?
Is it a 2xN 2D array where the first column is [s] and the second column is [φ]?
In any case, you can calculate df from dt and vice versa. The same applies for each dimension in the case of a 2D FFT.
Please claritfy what the problem is. Thanks!
(3,305 Views)
Hi ,
"through the continuous Fourier transform with respect to radial distance s and the Fourier series with respect to azimuthal angle φ where w is the radial frequency and k is the Fourier index."
After 2D FFT, i should get the  radial frequency "w" and the fourie index"k".
(3,293 Views)
(3,285 Views)
the transform is like this:
(3,279 Views)
