03-25-2011 01:37 PM - edited 03-25-2011 01:37 PM
This was working, but now no longer is. I have since installed 2010 SP1 but also got a new hard drive so I don't know exactly what changed. On my host I am wanting to get all channels and to populate a combobox because I like the look much better than an I/O control. However, DevNames is empty. If I drop a DAQmx device name constant, it is also empty and only gives me the option to browse.
If I drop the DAQmx Device Name constant on my code under the RT target, it finds everything. Is there something I need to configure to get it to recognize the devices from the host? My hardware is all showing up in MAX and I just updated the drivers to coincide with SP1.
03-25-2011 06:02 PM - edited 03-25-2011 06:10 PM
I'm going to rephrase this question:
How can I get the Physical Channels list from a remote device?
Lol, much more straight to the point. I just want this so the user can select which channels to view, should their wiring change down the road...I don't have to use shared variables do I...?
03-28-2011 07:39 AM
03-28-2011 05:28 PM
You said you can see all your hardware in MAX. Try creating a test panel in MAX to ensure you can communicate with your hardware. Are you able to run examples from the Example Finder in LV successfully? Try adding a simulated device in MAX. Does this device show up in LV when you insert a classic DAQmx Device Name I\O?
If you can successfully do all these things, there may be a MAX Database corruption.
Jordan
03-28-2011 08:45 PM
