How can i display 7 segment dispay on front panel using any kind of input
I need help..!! I need to dispay the numeric data in 7 segment format. Is it possible to do in labview?
Message 1 of 9
(6,919 Views)
Search on "seven segment font" to see where others have acked the same thing and learned how to do this using the right font.
Ben
Message 2 of 9
(6,916 Views)
you need to display the number onto a 7 segment display?
i think you would need sometype of microcontroller board like the AVR or the aurdino. and use the visa usb port to display out into the 7 segment display.
i am new to this too. but that's what i would do.
i hope someone with more expertise can  give better advice.
Arduino and 7 Segment LED
Digg!
Del.icio.us!
7 Segment LED
7 Segment LED
The seven segment display is a pretty simple device.  Its actually just 7 LEDs (8 really including the decimal point) arranged so different combinations can be used to make numerical digits.  This tutorial will show you how to wire one up and drive it with an Arduino.
Message Edited by krispiekream on 07-23-2009 11:48 AM
Krispiekream
Message 3 of 9
(6,915 Views)
Or use a DAQ card, 4 digital output lines and a 7447 or 7448 🙂
http://pdf1.alldatasheet.com/datasheet-pdf/view/27444/TI/SN7447.html
-AK2DM
Message 4 of 9
(6,886 Views)
wouldn't the DAQ card cost more?
when i was going to school, it was tough because most labview cards are really expensive. so i went with the arduino board to learn due to cost.
Krispiekream
Message 5 of 9
(6,876 Views)
how could you connect labview to arduino using four seven segment display?
thanks 🙂
Message 6 of 9
(5,668 Views)
thanks 🙂
You need USB interface for that
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 7 of 9
(5,652 Views)
@Ranjeet_Singh wrote:
thanks 🙂
And LIFA
Message 8 of 9
(5,601 Views)
I sure hope OP has solved the issue by now, 4 years down the road ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 9
(5,578 Views)
