How can i change automaticaly the type of output variable of a vi
i would like to put the variant conversion inside the vi on the left. ....but i dont find how do that ....and if it's possible!
Thank You
(837 Views)
The "type" is the same as wired on top of the variant conversion. You could probably make a malleable VI that has that type as input and where you can wire a constant.
(825 Views)
the type of the vi could be very different !
I would like make an "universal" vi ....but perhaps it's not possible !
(748 Views)
Hi Vincent,
As suggested by altenbach, it is possible by turning your existing VI into a malleable VI.
Rename your VI with extension .vim instead of .vi, then make it "Inline" (VI Properties -> Execution -> Inline subVI).
Then put your "Variant to Data" inside your SubVI. The "Type" should be an input of your malleable VI.
Raphaël.
(732 Views)
