How can do UnSubVI?
I think you'll have to open the sub-vi and copy out the content.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 15
(1,021 Views)
@GerdW wrote:
when I select a VI in the LabVIEW project explorer and press F2 I can rename that VI...
Gerd,
from my experience, F2 is not always working. Seems to be connected to language settings and/or OS version. But if F2 isn't working, right click for the context menu will always work....
Norbert
Norbert
Expert: Geometry
Message 12 of 15
(1,015 Views)
I think there is a more fundamental question here.  Why would you want to undo creating a subVI?  You obviously thought it was good to modularize the code by creating the subVI.  What is wrong with leaving the code as a subVI?
Message 13 of 15
(1,001 Views)
OT: I have big block diagram. Is possible somehow to get all diagram on one display? For example export all block diagram to one huge picture?
Thx
Message 14 of 15
(992 Views)
- ctrl-shift-n opens the navigation window...
- print the BD to a A0-sized PDF...
Message 15 of 15
(989 Views)
