How can I ....
use the pattern input on the file dialog function to filter a directory for
files containing a number of different extensions?
I can only make it filter on one extension using *.xyz on this input.
Ta very much,
Jeff
(4,290 Views)
It's trivial to use a for loop with N equal to the # of extension you're
looking for ?
Antonio
Jeff Abell scritto nell'articolo
<01be9db0$db684040$7ec69b82@queeg.tip.csiro.au>...
for
> Ta very much,
> Jeff
(4,290 Views)
Separate each pattern with a semicolon.
Example: " *.exe;*.vi;*.ctl "
ej
In article <01be9db0$db684040$7ec69b82@queeg.tip.csiro.au>,
directory for
> Ta very much,
> Jeff
--== Sent via Deja.com http://www.deja.com/ ==--
---Share what you know. Learn what you don't.---
(4,292 Views)
Hi Jeff,
ej
directory for
> Ta very much,
> Jeff
(4,291 Views)
Hi
for filtering specified datalog type file from specified directory,we have to mention either paterrn or datalog type in List Directory function,can i have any example for filtering to different sort of files like one is labview specific datalog and other one is any ASCII file
Can you attach sample VI for read different files with extension *.exe;*.vi
(4,033 Views)
