How can I write commands forTektronix AFG3102 which is not available on IVI driver?
How can I write commands for Tektronix AFG3102 which are not available on IVI driver?
I need to write commands for setting Pulse period and pulse width of a pulse wave which are not available on the IVI driver. Labview 8, WinXP.
thanks in advance.
(3,492 Views)
There is a subVI that should allow you to send these commands to your instrument. The VI is called tkafg3k Write Instrument Data.vi and is located on the Functions palette under Instrument I/O»Instrument Drivers»tkafg3k»Utility Functions»Instrument I/O. You will need to find the corresponding command in the instrument's manual, but you should be able to write this command using the tkafg3k Write Instrument Data.vi. I hope this helps!
Missy S.
Project Engineer
RoviSys
(3,464 Views)
