06-12-2006 02:31 PM
06-13-2006 03:45 AM
06-15-2006 10:05 AM
Sorry it took so long to get back to you.
I tested it on the computer that is having problems, and I installed the developemnt environment on it so I could see the errors. The type mismatch was caused because I did not have any data in the excel sheet. As soon as I put a name in the sheet, it worked fine, so I thought.
If I run the read config by itself, it works just fine, closing excel and the process. But as soon as I run it in my main vi, it does not close the reference and keeps the process open, so I cannot run my save vi (saves the user info and the data), although I can write my config data back to Excel. In both the config data and the save data I am using the Excel easy vis.
If I try to save my data, Excel opens, but freezes and the table is blank (which I read and can see that the process is still in memory). But it is wierd that I can still save to my config file.
Kenny
06-15-2006 01:48 PM
Another thing I noticed. When I abort the vi, excel.exe disappears from the task list, as well as if i just close labview.
Not sure if this matters.
06-19-2006 09:08 AM
06-20-2006 03:12 AM
06-21-2006 07:46 AM
