How can I use Labview real time with Interval Zero RTX real time os
I want to use LabVIEW in order to build a real time application using a PC, in the PC an RTX operating system will be installed, however, i am not sure the compatibility of Labview real time with that system,
can anyone confirm to me if it is possible to do so?
thank you
(3,855 Views)
LabVIEW uses it's own RT system (basically Phar Lap ETS in case of desktops). You cannot use it with anything else.
(3,852 Views)
 I want windows to be installed along side with RT system, can this be done with the phar lap ETS case?
(3,839 Views)
Yes.
Although if you want to run them at the same time, you will need a hypervisor.
(3,833 Views)
thank you stockson,
however it says that hypervisor reach end of life in 2016 is there a replacement or another solution?
(3,821 Views)
