How can I take control of the context-sensitive help for ActiveX methods and its parameters?
with the context help enabled we would like to show help for an ActiveX method and its parameters. Per default the method is displayed with its parameter names and types. How do I add text for each parameter and the method itsself. Some good links to web pages or a good document would be fine and very helpful.
Thanks a lot,
Sven.
(2,648 Views)
Hi, when you create your COM, you can add help file (WinHelp file), there you write for each property and method any text. When you distribute the COM you have add also the WinHelp file.
(2,648 Views)
