How can I synchronize the display of AVI video and digitized analog signals?
I am recording high speed AVI video (independent of LabView) and digitizing an analog signal via LabView.  Both the video and analog signal display a common event so that I can synchronize the two data streams.  I would like to write a vi that can synchronously display the digitized analog signal and the video.  Is it possible to do this using LabView?  Any example code that might help?  Thanks!
(3,000 Views)
to play an AVI you may use the media play ActiveX plugin, VLC ActiveX or Quicktime ActiveX
using the Windows media player: http://decibel.ni.com/content/docs/DOC-2207
using the VLC player: http://forums.ni.com/t5/LabVIEW/Embedding-Windows-media-play-in-LabVIEW/m-p/1068703#M473716
using the quicktime player: http://forums.ni.com/t5/LabVIEW/Pragmatically-using-Quicktime-ActiveX/m-p/1186347#M513367
(2,983 Views)
Does any know the answer to this question,  I just might have to do something similar soon. A very high speed video camera (not connected to LV)watching an event that triggers a pulse that IS connected to LV. No problem capturing the event as a digital input to LV. Is there some way to relate the triggering event to the frame number on the high speed camera? I don't need LV to capture and store the video just the frame number. i know this is vauge but it is all the information I have so far, I have been told it is possible.
Alan
(2,914 Views)
