How can I send text file to printer port?
Can you post your vi?  If you look at the image I posted you should be able to reproduce my vi.  It should do exactly what you need.
Message 11 of 35
(4,147 Views)
@filozof wrote:
I need to print a txt file from printer. I use sys exec.vi and bat file to do this. Bat file contains copy C:\plot.txt to lpt2  command. How can I do same issue with labview icons?
Hi filozof,
I'm not sure whether you understood(?) - no batch file is needed,  you could make a string="cmd /C "copy C:\plot.txt lpt2""
and wire that string to the System Exec.VI "command line" parameter.  System Exec.VI has a LabVIEW icon.
Or follow centerbolt's example and write to a "local printer" using the "Report Generation" VIs.  The fact that you're printing a VI's front panel proves this technique should work - what did you have "File Path" set to?
If you're feeling masochistic, it might even be possible to write directly to "LPT1" using VISA Write, Smiley Surprised though a form-feed command was often needed (in the old days) to see the last/only page of text.  To send a form-feed to the parallel-port, would be painful (but is possible).
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 12 of 35
(4,144 Views)
yes it prints text file thank you so much.
Now i try your command at he sys exec icon without batch file. I write string  cmd/c"copy C:\plot.txt lpt2" at the command line sys exec.icon. But It can not print.
Message 13 of 35
(4,124 Views)
Cmd /C "C:\plot.txt >lpt2" after using this command printed page include "1 file(s) copied.
Message 14 of 35
(4,120 Views)
Cmd /C "C:\plot.txt >lpt2" after using that ,printed page shows just"1 file(s) copied.
Message 15 of 35
(4,122 Views)
Maybe my mistake.
Try replacing "lpt2" with "prn2".
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 16 of 35
(4,121 Views)
Printer prints only "1file(s) copied." Port is correct but I don't understand that when I use batch file,I can take print with c:\plot.txt  lpt2
instead of that, I write Cmd /C "copy C:\plot.txt >lpt2" in the command line in sys exec.vi, Printer prints only "1file(s) copied."sentence
Message 17 of 35
(4,110 Views)
You may want to take a look at the Windows API VI libraries. You will find a library called winevent.llb. Within this library is a VI named FileMan Print File. You can simply wire a path to a file to this VI and Windows will use the default application to force the specified file to print. If you have a text file saved on dick, you can use this VI to print the text file. I hope this helps!
Mike D.
Message 18 of 35
(4,098 Views)
If you have it working in a batch file, you can also call the batch file from LabVIEW, or simply use the text contained within the batch file for your system exec function (with cmd /C as prefix)
Shane
Message 19 of 35
(4,093 Views)
I have sys exec. file and batch file.Batch file contain copy c:\plot.txt lpt2. When I write location of batch file in command line of sys exec. icon, I can print. But I want to improve that method. I don't want to batch file to copy c:\plot.txt lpt2.
Some friends said that no needed to batch file to copy, use Cmd/C"copy c:\plot.txt> lpt2" to command line.  when I do that, Printer sends only "1file(s) copied". It does not print text file.
Message 20 of 35
(4,089 Views)
