How can I resolve this error IMAQ?
Please give me information about this type of error.
Message 1 of 13
(4,046 Views)
What error are you talking about?
Message 2 of 13
(4,032 Views)
Where is the error...???
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 3 of 13
(4,031 Views)
when I want to start program comming this error and shows that IMAQ Write JPEG File 2 Is wrong
Message 4 of 13
(4,019 Views)
Have you tried wiring an indicator to 'Image Out' output of 'Kamerainställningar gigE_2(SubVI).vi' and check, if actually there is an image available at this output??
Message 5 of 13
(4,013 Views)
No. How can I do that?
Message 6 of 13
(4,002 Views)
You can find the same from 'Controls Palette' as shown below:
And on the 'Block Diagram', you'll see a terminal corresponding to this indicator. very similar to below picture... and that you need to connect to the wire.
Message 7 of 13
(3,999 Views)
I tried to delete it and fix another thing to save pictures! can you suggest another way to save pictures?
Message 8 of 13
(3,998 Views)
Actually i did it but I must find a way to save pictures JPEG
Message 9 of 13
(3,991 Views)
To save a picture, you must be sure that, there is a picture available...!!
Try the attached code, and you'll see that 'IMAQ Write File 2' works beautifully, without any flaw..!!
So I suspect, the error you're experiencing is because there is no image available.. or also may be because there is an incompatible image that you're trying to input to 'IMAQ Write File 2'..!!
Message 10 of 13
(3,984 Views)
