How can I remove repeated elements in an array
just for the sake of different solution
ofcourse valid only for positive numbers in array.
Christian, Is it fast?????
Message 11 of 38
(3,224 Views)
Probably not, because with every iteration you compare the current value with every single value in the shift register array. N² comparisons for a size N input array. A 100x bigger array needs 10000x more comparisons!
Not tested.
Message 12 of 38
(3,216 Views)
OK Christian,
I think i got your point. ( i never thought that way ):smileysurprised:
Now i have one more idea, if i can insert 1 array subset function with index zero and length of array from lower shift register. That will only give me any array of limited elements so limited comparison but i will end up with an extra copy of array for array subset.
Am I right ?
So still not fast
Message 13 of 38
(3,209 Views)
one more attempt
If array has zeros also then shift register comparison will start from -1.
Message 14 of 38
(3,198 Views)
@Neos wrote:
one more attempt
This is getting better, however if the sorted input array starts with a zero, the output would be wrong. Right?
You can also save some array buffer allocations.
Also note that this idea would make things a bit simpler. 😄
Message 15 of 38
(3,193 Views)
@altenbach wrote:
@Neos wrote:
one more attempt
No, I edited my reply, use -1 in place on 0.Smiley Wink
Where am i missing??Smiley Surprised
KudoedSmiley Very Happy
Message 16 of 38
(3,186 Views)
Anyway, since you are getting close, here's my benchmark I wrote earlier, compairing 4 different code versions. Mine is pretty standard code and I suspect that the openG version is similar (not checked, because I don't have it). The main technique has been discussed many times in the past (e.g. here is my post from 2005).
Attached version is in labVIEW 2013, but I also attached a LabVIEW 9 version. Do you need older?
Message 17 of 38
(3,184 Views)
Neos wrote:
No, I edited my reply, use -1 in place on 0.:smileywink:
 Then you will have a problem if the sorted array starts with -1. 😉
Note that you need two full sized arrays (1) the sorted array, (2) the initialized array.
If you look at my code, you will notice that I place the sorted array directly into the shift register. Since we always read from the unmodified section, there is no problem operating only on one single array.
Message 18 of 38
(3,179 Views)
I am not able to open your VI ( 2009 version ).
It say LabVIEW error load 3, could not load front panel.
Message 19 of 38
(3,173 Views)
Well, it opens just fine back in 2013. Maybe there is a downconversion bug. What version are you using?
Here's LabVIEW 8.2 version. See if this works better.
Message 20 of 38
(3,168 Views)
